跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Broken screen replacement query
My Mid-2014 15” Retina MBP has a broken screen (A3198 emc 2881). My friend has a 15” 2012 15” Retina MBP (A1398 emc 2512) he no longer uses. Is there any way I can replace my faulty screen with his, or are the two totally incompatible?
Sorry if my question is stupid, I’m having a hard time finding out online.
Many thanks,
Dan.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Unfortunately the display from the 15-inch 2012 Retina MBP is not compatible with the 15-inch Mid 2014 Retina MBP. You can see the compatibility for each display listed here and here.
Replace a display compatible with the model A1398 Mid 2012 to Early 2013 15" Retina MacBook Pro laptop. Includes the 2880 x 1800 15.4" Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, Wi-Fi antenna, and cables for display data and camera. Part #661-7171, 661-6529.图片
产品
MacBook Pro 15" Retina (Mid 2012-Early 2013) Display Assembly
$394.99
Replace a display compatible with the model A1398 Late 2013 to Mid 2014 MacBook Pro 15" Retina laptop. Includes the 2880 x 1800 pixel 15.4" Retina LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.图片
产品
MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
$319.99
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much!
完成的
添加一条评论
添加你的答案
Dan Gilmour 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 100
