跳转到主内容
加入维修社区 - 创建账户
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Dead shock I'm almost dead
Man ... I repaired a lot of iMacs. But this is the first time I have received a fatal electric shock from the power supply. It was horrible ... why does it come like this ... And it doesn't work at all ...
IMac power supplies are harmless, right?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Far from it! ALL power supplies have capacitors!
These can hold affair amount of energy. So when you cross your hand across the contacts you can get a very good Zap! Touch one contact with one hand and the other from the other and you can stop your heart! With dire conquests
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement In Step 10 there is a very clear warning!
“The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.“
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ajimoza10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 347
