跳转到主内容
Toyota's fifth generation Pickup
91 个问题 查看全部
My 94 toyota P.U. won't start the second time I crank over?
When I initialy start my truck it starts fine and I can drive it with no problems. But when I shut the engine and try to start it again it wont stay on. It will crank over like it wants to start but dies down. I have replaced the Module, coil, fuel filter, plugs and wires, cap and rotor, and the throttle position sensor. I don't know what else to check? Please advice
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Will it restart after it cools down? What engine do you have in your Toyota and what tranny?
完成的
It will restart after a few minutes. Its a 22re with automatic transmission.
完成的
添加一条评论
9个答案
已选择的解决方案
Since the problem only happens once the truck is warm, I would check around the engine for any loose fittings or hoses that might have expanded and started to leak once they were warm. It would probably be a big leak to keep the engine from starting entirely, so open the hood with the engine running and listen for any hissing or sucking noises. Pay particular attention to the intake manifold. A vacuum leak can wreak major havok on an engine's ability to run.
Another possibility is a faulty O2 sensor. It will be plugged into the exhaust on the engine side of the catalytic converter. It's possible that that is reading wrong once it heats up.
From the parts you say you've replaced, the only thing left to check is whether or not your fuel line pressure and flow is adequate. It's a pricey thing to replace, so I would get a fuel system testing kit from your local auto parts store and check that your pump is delivering adequate pressure AND flow. (Though a good kit is also expensive. It may be cheaper to just replace the pump) It would also be a good idea to make sure none of the injectors are sticking, though a good dose of a fuel line cleaner can usually remedy that.
这个答案有帮助吗?
得分 2
4条评论:
try replacing regulator in fuel tank ,worked for my toyota
完成的
there is no regulator in the fuel tank
完成的
Could I just ask Jhun what the actual problem was with his PU in the end. As I have just purchased a 1998 Toyota Hilux and it is doing exactly the same thing. Although, it takes much longer than a few minutes to start after stopping, more like a few hours. I have brought it in to my local garage and they have recommended having the diesel pump checked. Just wondering if it was the fuel pump that was the problem in the case mentioned above, as it is a bit pricey to replace.
完成的
I changed my COR and still not starting now. I have. 3VZ motor on my 94 2wd pickup. Now it just cranks over . I checked cold start and no fuel is coming through. Any help is appreciated.
完成的
添加一条评论
What I would start with is the symptoms of why it doesn't start. Is it getting fuel on the second crank and spark? Thats where i would start from and post results and we can go from there!
这个答案有帮助吗?
得分 0
2条评论:
It will restart after a few minutes. Its a 22re engine with automatic transmission.
完成的
replace regulator in fuel tank
完成的
添加一条评论
It might also be your ignition relay. Usually it isn't smart to just throw parts at a car but after looking at all the parts you already replaced a ignition switch makes quite a bit of sense to me.
这个答案有帮助吗?
得分 0
添加一条评论
could be a timing problem,check the timing after engine is hot.
这个答案有帮助吗?
得分 0
添加一条评论
Got same problem on my 94 i have put new fuel pump, massair, an ingition switch an relay. I have found out that when it want crank there is no power to injectors for some reason. Help
这个答案有帮助吗?
得分 0
添加一条评论
try replacing regulator in fuel tank if your car is hard to start when hot ,worked for my 2007 toyota
这个答案有帮助吗?
得分 0
添加一条评论
There's some great suggestions in here, you can use the Toyota repair manual as well for bolt torque specification and for issues you cannot figure out yourself.
Have a look here: toyota hilux 1989-1998 repair manual
这个答案有帮助吗?
得分 0
添加一条评论
Most likely your radiator is not keeping your engine cool enough so i should check the hoses and wires like the other guy said and then take it to a auto zone, o'reilly's or some time of a place like that's near you then ask them to check the radiator and if it's faulty then just change it also they will know if the the hoses could messed up as well and they should check it for free.
这个答案有帮助吗?
得分 -1
2条评论:
David, if it would be an overheating issue, it would not "restart after a few minutes" Rethink your answer.
完成的
完成的
添加一条评论
suggest replace alternator and/or battery
这个答案有帮助吗?
得分 -1
4条评论:
Derek Dee, why? If your alternator would not charge or the battery would not hold a charge, it would not " restart after a few minutes" and hopefully Jhun got it fixed in the last 8 month :-) Changing parts without proper trouble shooting can get pretty expensive.
完成的
what would you do then? leave it be lol
完成的
I actually agree with Mario T on this one...makes a whole lot of sense
完成的
It might work.
完成的
添加一条评论
添加你的答案
Jhun 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 10,442
