跳转到主内容
Released in 2018, the Lenovo IdeaPad 330 is part of the IdeaPad 300 series, a class of home and office PCs.
7 个问题 查看全部
Screen replacement upgrade or trade in?
With my lenovo 330 ideapad model 81de would it be possible to upgrade with lenovo parts to a 1080hd resolution instead of 768? It's a great clunky laptop I enjoy. I want to also upgrade my ssd to 2tb instead of the 500gb ssd I put in it. I also want to put a 16gb 2133 ddr4 sodimm for a total of 20gb ram. Currently there is a 4gb 2133 ddr4 sodimm soldered to board and a 3200 8gb sodimm in the changeable slot. But if the screen display is not upgradable with some work then I will trade in sometime and save the upgrades for next laptop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Looking at the parts list for your model, it seems that FHD LCD panels i.e. 1920 x 1080 are compatible. Click on Select Commodity > LCD panels (8) to find the Lenovo part number. Searching online using the part number only will get results for suppliers of the part.
Here’s the hardware maintenance manual for the laptop that will help with doing any hardware changes/upgrades etc.
According to this supplier a 2TB SSD will work but it needs to have a 7.0mm to 9.5mm adapter to ensure that it is positioned correctly in the drive bay to make a solid connection with the sata port connector
这个答案有帮助吗?
得分 1
1条评论:
Thank you I learned something new about manuals thank you for quick reply
完成的
添加一条评论
添加你的答案
The Prince 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 245
