跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
20 个问题 查看全部
Pressure/books/clamps on screen replacement to help cure adhesive?
In general, when I've done screen replacements on phones I've placed a book or books on top of the screen for hours in order to help the adhesive make a strong bond. What is the recommended practice for this, with regard to force and length of time, or do you not do this at all? I do not want to apply too much pressure and damage the screen replacement, or too little and have the screen not be flush against the chassis.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I have used clamps in the past they work excellent. I use a heat pad and clamp combo on pixels, ipads and many other devices. Qianli clamps are my go to, they are compact and easily adjustable. I think it's important to heat up the device, no more so than when ur trying to remove the adhesive then clamp away and leave for about 10min. books and other flat objects with adequate weight work as well. Use what u have until u get what u need for a proper set.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jeffapm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 935
