跳转到主内容
加入维修社区 - 创建账户
Screen backlight only half working
Over time my MacBook has been developing an issue, at first when I pressed the bottom area of the screen bezel it starts doing something I don’t really know how to describe, so I attached a photo, and the screen is noticeably dimmer. Currently I don’t have to do anything for it to happen, and even worse, sometimes it flickers, however the backlight never fully turns off. I tried running the laptop with the bottom off and pushing the display cable, but it didn’t do anything, so I’m assuming it’s something inside the display.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You’ll need to do a bit more digging to isolate out what’s needs fixing.
Follow this guide 2011年末 MacBook Pro 13" 一体化机型显示屏更换 doing the first steps to disconnect the battery, then jump down to Step 14 carefully disconnecting the LVDS cable and inspect it and the logic board connector for corrosion
The other end of the cable is a bit harder to get to as that too can face the same problem. At which point you would likely need a new display to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iSzymon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 266
