Front camera and face ID and rotation issues
Hello, i have an xs max dropped in water and they put it on charge, the phone was dead , so i teared it down and cleaned it( seperated the layers) the phone turned on again but i have two issues:
_ the front camera and the face ID not working, checked everything all the software solutions and checked the flex and the plug, checked the voltage on plugs eeverything working normally, do you think it is a lack in the layers assembling?
_Screen rotation worked on the first day but then it stopped, i tried also all software options, also changed the screen still the same ( knowing that the compass is not working but the maps are working normally.
Please advice, thank you.
6条评论
I still dont understand
由 Keshawn Vasugan 完成的
what happened
I have a water damage xs max, it was dead then i fixed it but Front camera and Face ID are not working, i already tried all the software option but still not working checked the flex and the plug still not working, even the voltage on the plug is good, and the screen rotation is not working even after i tried all the software options
由 Mahmoud Baroudi 完成的
What do you mean by “the voltage on the plug is good” What voltage and what plug?
由 Chris Stables 完成的
@imicrosoldering i mean the Camera connector on the board, i checked the voltage that sould be on connectors, data and ground,
显示更多的1条评论
