跳转到主内容
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
video showing the steps to replace new Power Button for HP 250 G3
Is there a video showing the steps to replace new Power Button for HP 250 G3 Laptop
Regards Bob
Update (03/06/2021)
Thanks for your reply, do you approach this job from back of computer, not the keyboard side
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @bsuther ,
Not a video but here’s the maintenance and service guide for the laptop.
Go to p.50 to view the necessary pre-requisite steps and then the procedure to remove/replace the Power button board.
Replacement boards are available online. Just search for 749650-001 to get results for suppliers.
这个答案有帮助吗?
得分 2
1条评论:
Hi @bsuther ,
You access by removing the keyboard and the top cover then flipping the top cover over.
Just follow the guide.
The steps are there on p.50.
Step 4, 5 & 6 tell you which page to go to in the manual to see how to do the procedure for each step then it shows how to remove the power button board. There are pictures.
Re-assemble in the reverse order.
You can't access from the back (bottom) of the laptop as the motherboard is mounted on the base and you would have to remove it first to get to the power button board. The motherboard has to be accessed the same way by removing the top cover as that side has the screwheads for the screws holding the motherboard in position.
Access to everything is by removing the keyboard and top cover
完成的
添加一条评论
添加你的答案
Bob Sutherland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 305
