跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
67 个问题 查看全部
Xbox series X not turning back on after crashing
So I downloaded Elite Dangerous on my Xbox but it kept crashing, so I tried one more time, then it crashed fatally,and turned off my xbox completely, it did switch on after that with a cold boot, but as soon as it loaded up the homescreen, it shut off again, since then it hasn't turned back on, when I press the power button the logo does glow up and emit the startup sound but it shuts back off after a couple of secs, so I peeked from up top and then saw that when I press the power button the fan doesn't start up with it, which it should and then my xbox turns back off as the fan doesn't start up, but sometimes when I press the power button i do see the fan move a bit, like it tries to spin but then stops soon after and shuts off the console, the disc drive still accepts and ejects discs but hard reset, usb update, troubleshooting mode, none of these methods work, it has been originally imported from Singapore to India so here in India the power outlets have 220v instead of 120v in Singapore, could this be a power supply issue? i use it with a pin adaptor which is rated as 6A, 240V
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello. I’m sorry to hear this but this is probably a power supply issue. Try replacing it. If it still won’t work, it’s the voltage that the console is receiving.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 344
