跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS won't charge after battery replacement
Hi,
I bought new battery for my 3GS. Using the iFixit guide I replace it. But i think that I broke something while unscrewing. Now my 3GS won't charge. I attached photo with marked broked "thing". How to fix it?
http://imageshack.us/f/263/p1010596f.jpg...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hello,
Possible solutions:
1) Insure that you replaced the battery with the correct one for your phone. The 3G/3GS ones look similar, but have vastly different internal structures. Insure the battery you replaced yours with has a model number the same, or the last digit is the only one that is off.
2) While I suspect that the part broken may have part to do with the charging issue, I'd recheck all the connections, focusing on the dock one.
3) If that does not work, I'd try replacing the dock for a new one.
4) If none of these worked, your board is likely shot. You can try soldering that spot or bringing it to someone that can. However, I do not know of a repair guide for this problem.
Hope this helps,
Xico Solutions
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kacper Sztechman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 953
