跳转到主内容
A high end laptop, made from Aluminum and Carbon fibre chassis, that Dell manufactured in 2018.
10 个问题 查看全部
Electrical noise coming from the center of the laptop
I’m hearing an electrical noise coming from the center of my laptop. It sounds like voltage jumping over a small gap.
It’s not related to the fans.
this is the noise. Ignore the birds chirping in the background:
https://drive.google.com/file/d/1LCkWJ8S...
The noise is coming from this area of the laptop:
Is this normal behavior, or should i have this looked at?
Could this be resolved by unplugging and replugging certain connectors?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Either way it needs a thorough clean. Download the service manual PDF www.dell.com/support/home/en-uk/product-support/product/xps-15-9570-laptop/docs carefully clean it. May be some short circuit is happening, Clean it well..
完成的
添加一条评论
1个答案
Not sure I heard exactly the sound you’re getting at. I had a problem back in the day which had to do with speed-step. Disabling that in the bios helped. It was a sort of electric sound from the processor. Highly annoying. can’t say if it’s the same sound you’re experiencing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bert Verhelst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 229
