跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 个问题 查看全部
Battery reboots sporadically, trying to determine where the issue lies
As title says, the battery is causing the device to sporadically shut down and reboot. The battery percentage is also not properly reflecting charge level as it will show a different percentage when charging and when off the charger. I know it is the battery in question and not the device’s hardware or software since I tested this on multiple devices.
I am trying to see if I can address this issue by cycling this battery or doing something else to the battery. I can charge the battery fine, however my machine cannot discharge the battery and fails every time. I am using the two large terminals on the battery as my contact points, which works for charging, however do I need to use a different pairing to for fully discharge it?
We are located in one of the heavily affected areas from the cold snap and shipping is severely delayed, hence my trying to fix the battery instead of just getting another.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can’t really ‘fix’ a battery. These lithium ion batteries only have a limited lifespan. It sounds like your battery is just bad. I would wait until you can get a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Saied 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 19
总计 49
