跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Qualitative differences between regular screen and Pro LCD + digitizer
I’ve replaced the screen on my 6S Plus once already, and unfortunately I have to do it again. The 1st time, I used an iFixit replacement screen, because it had all of the small items attached, and it seemed like a better deal than the LCD + digitizer Pro screen.
But…if I pay the extra money and spend the extra time to install the Pro screen, will I see or experience a noticeable improvement in still/moving images? Are there other advantages to the Pro screen? The iFixit description doesn’t really describe and qualitative differences, so if anyone out there can answer this question, I’d really appreciate it.
Cheers!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
If you don't mind paying extra you should buy a refurbished screen
完成的
I’m assuming you’re referring to the LCD + Digitizer. Why?
完成的
添加一条评论
1个答案
It’s pretty easy to transfer the small parts like the front camera and ear speaker to a new display. If I were you, I would spend the couple extra bucks to get the original LCD. While there are good quality aftermarket displays out there, they still don’t quite compare to the original as far as color but it’s hard to notice unless you’ve got them side by side.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Pineda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 68
