跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
239 个问题 查看全部
Reddish tone appears just for a fraction of sec on iPhone se2
When ever I turn down the brightness of my iPhone se2 from max to min just like instantly I see a reddish tone on the screen just for a fraction of second then it’s normal I dono that is it a device defect or it’s there on all iPhones . It’s only when I do the brightness change very rapidly and from max to min it’s visible easily but it’s only when turning the brightness and it’s gone like instantly ,it just appears like a reddish color on screen . Is this a defect should I replace my phone because it’s just bough very recently and I still have that option .is this happening on all iPhone se 2 .please anyone answer and if u have iPhone se2 then please even check by increasing your brightness to max and instantly reduce it to min on white and high to low instance change of brightness it’s easily visible ,if it’s there then it’s a problem on all se2 devices or is it a normal thing with iPhones please answer my question ASAP. thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Akshith,
The phone came out less than a year ago. If you have any concerns or issues with the phone you should contact apple / your retailer immediately. It doesn’t cost you anything and worst-case scenario they decline your replacement. There’s no point in trying to fix it yourself as you may void the warranty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Akshith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 31
