跳转到主内容
iPad (第七代) 的維修以及拆卸指南
120 个问题 查看全部
iPad 7 in boot loop, even after successful DFU mode restore
Hello here is my issue: a customer brought in an iPad 7 with a shatter screen that we need to fix, but it also has a boot loop issue. The apple logo comes up for about 10-20 seconds, then it turns off, and comes again, and so on. I tried a recovery mode restore, but it would fail with some kind of error, so I did a DFU mode restore and it worked; iTunes says the restore is successful and the iPad is restarting, but then the bootloop happens again. Any help would be appreciated!
Quick side note: I read somewhere in one of the apple forums where someone had a similar issue and said it was hapening because of lack of charge, so I am going to leave it plugged in overnight and try DFU restore again tomorrow. In the mean time, any suggestions or thoughts would be great, thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Start by connecting your iPad to its Power Adapter and allow the iPad to charge for at least an hour - or possibly overnight. This step is advised as a battery with very low charge, or is failing, may produce symptoms that emulate a boot loop.
If the problem fails to stabilise, while still connected to the Power Adapter, attempt a forced restart of the iPad:
Force restart iPad (models with the Home button)
Press and hold the top button and the Home button at the same time. When the Apple logo appears, release both buttons.
If iPad still doesn’t turn on, or if it gets stuck during start up, see the Apple Support article If your iPhone, iPad, or iPod touch won't turn on or is frozen. Or if your iPad isn’t working correctly after you restart it, see the iPad Support website.
If your iPad is stuck is actually stuck in a boot-loop, you’ll need to resolve this specific issue - which may entail “restoring” the most recent version of iPadOS to the iPad. This support page outlines restoration of an iPad to Factory Settings:
Restore your iPhone, iPad or iPod to factory settings – Apple Support
You’ll need access to either a PC (with iTunes installed) or a Mac (with iTunes or Finder - as appropriate for the installed version of MacOS).
Download and use iTunes for Windows – Apple Support
Update to the latest version of iTunes – Apple Support
Use of a PC or Mac computer is unavoidable. If you don’t have access to a suitable computer of your own, that of a helpful friend or family member will suffice. Alternatively, the technicians at the Genius Bar of your local Apple Store or Apple Authorised Service Provider (AASP) will be delighted to assist.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Armen Orbelyan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 21
总计 161
