跳转到主内容
Repair and further information for the GE Profile Refrigerator PYE22KSK****, a 2016 built-in, French door refrigerator with a bottom-mounted freezer and automatic defrost system. This page covers information for model numbers matching the pattern PYE22KSK****.
3 个问题 查看全部
GE Profile Refrigerator making revving sound.
Hello. I have a GE Profile PYE22KSKSS refrigerator and it has started to make a revving sound from the refrigerator compartment. It is intermittent but has been occurring for several days. It is worth noting that prior to this happening I noticed some food in the refrigerator that started to freeze. A separate post suggests this is normal “thawing” functionality but I cannot find any reference to this in the manual. Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @scottie3535 ,
Ideally the food should never freeze in the refrigerator compartment so maybe there is a problem with the temperature sensor in the refrigerator.
The revving sound may be the evaporator fan in the refrigerator compartment going into high mode trying to cool things down more quickly. As to why this should be happening I don’t know
This is only a guess because your model has two evaporator units each with a fan, one in the freezer and the other in the refrigerator so the two compartments are independent of each other for cooling.
Here’s the tech data sheet- part #31-51932 for the refrigerator (I think it is anyway), found by searching for the part number as shown by this parts supplier. (part #999- dispenser door diagram)
This shows how to get into the diagnostic mode so that you can check if there are any error codes pertaining to the refrigerator and also test the sensors on the refrigerator.
FZ=refrigerator and FF= freezer
Hopefully a start
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 52
总计 2,501
