跳转到主内容
Repair guides and support for your Toshiba TV.
193 个问题 查看全部
Led issue or board?
toshiba 50l711u18 back light turns off after 5-9 minutes of use. I can see picture with flashlight. I can’t see any light from air vents when black screen. I have factory reset. Unplugged for 10 min. Nothing seems to help. Would this be a board or led issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
It could be either or both. If you have backlight for 5-10 minutes it tells me that it manages to drive the LEDs however, something in the circuit cannot sustain the power delivery. I'm guessing capacitors that are drying out on the backlight circuit.
完成的
添加一条评论
1个答案
Does the red light by the power button give you a code by flashing a certain number of times? It sounds like you'll need a replacement board. Models like yours usually don't have individual led driver or backlight inverter boards. Those are probably part of the power supply board. You can take the tv apart and remove the screen to access the led strips. You can test each light with a multimeter and should read 3 volts at each one. Sometimes the connections on those strips are bad and you can fix them with a soldering iron. It's a bad connection/component on one of those. You can inspect the capacitors of the power supply/led board for visable damage just by opening up the back and using a flashlight. They're will be larger caps grouped closer together on half the board which is the power supply side. So you'll want to look at the smaller spread out ones on the opposite side. They're usually 10-35v ones usually blue, black or brown tubes with an x on the tops. Look at that x and check if it's puffed up. They should all be flat. You will be able to tell if you've found a puffed one compared to the rest. If you do find a bad cap it is 99% that board. Or you could just replace the caps. If not I'd check the led strips for bad connections. Hope that helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samitch24 D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 17
总计 475
