跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
Which is power connector polarity?
I would like to adapt a power supplier of mine for my old 3DS (maybe building up something like a dock-station), I found specification of the input current (4.6V, 0.9A), but I have no idea about polarity of the connector. Which is + and wich is - ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Mick,
For battery connector: When you open the 3DS it tells you which pin is plus and minus on both the 3DS battery slot and the battery itself. You shouldn't need the middle pin to turn it on i don't think.
For the charge port at the back: There are only 2 pins. Set it on a desk with the port facing you. Left is - and right is +
这个答案有帮助吗?
得分 1
2条评论:
Do not confuse the polarities unless you want to fry your 3DS, permenantly.
完成的
What is left if you hold it upside down, is the rounded corner down?
完成的
添加一条评论
添加你的答案
Mick 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 54
总计 968
