跳转到主内容
Game Boy(Game Boy 掌上游戏机)于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
How do I fix my battery spring corrosion
I have an original Gameboy but the battery springs are corroded.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you want to clean the corroded spring, you could dip a cotton swab in isopropyl and rub it on the spring, it could help a bit. But I’d recommend buying new battery terminals, depending on which contact is corroded you’ll have to do a little bit of desoldering, as there are 2 contacts in the upper part of the battery case which are soldered to the gameboy’s circuit. The ones circled in the image below to be more precise. The squared ones are just terminals which can be easily popped out of the case and replaced, you can find them easily on the internet.
这个答案有帮助吗?
得分 1
2条评论:
So on the Internet I found the terminal and can only buy 20 and shipping $8 bucks. I won't do it?
完成的
Also alcohol does nothing. Maybe dip in vinegar for 15 min then make baking soda/Water paste and a toothbrush . Then use a knife and Emory cloth on metal..
完成的
添加一条评论
It very much depends on how bad the corrosion is. Light corrosion could possibly be fixed with IPA and a toothbrush, for something more serious I'd let it sit submerged in vinegar for a few hours. The last option is to use sandpaper and sand off the zinc coating to expose the copper underneath
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dominik Havlicek 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 158
总计 14,579
