Will I lose True Tone if I replaced the Front Camera and Sensor Cable?
iFixit Guide: iPhone 8 Plus Front Camera and Sensor Cable Replacement
No, You will lose True tone if you Change the Screen.
这个答案有帮助吗?
If you're Changing your Screen you will need to reprogram your Screen to your iPhone 8
This is not the correct answer, after changing the sensors true tone does not work
The marked answer is not correct, after changing the sensors true tone does not work!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 270
1条评论
Yes bro its will be lose,True tone is connected to the light sensor also
由 yones rasti 完成的
