跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
How do you fix a Mac backlight?
My friends’ mac had the spotlight issue on the bottom of his screen and a few minutes later the backlight went out. Wanna know if that’s something I can fix. I have the pro-tech kit and I know how to fix iPhones and Windows laptops but I’ve only ever explored a mac and not fixed one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This is a known issue: The Design Flaw Behind MacBook Pro’s “Stage Light” Effect And 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
As it turns out there is a extended warranty program for your system! 13-inch MacBook Pro Display Backlight Service Program
So take advantage of the Free Repair!
完成的
添加一条评论
1个答案
Hi Matthew!
Great question!
  1. This issue IS fixable despite what the big bitten fruit may claim.
  2. This issue will require more knowledge and tooling than a Pro-Tech kit alone. This repair will require board level diagnostics and micro-soldering to repair most likely - although it is certainly possible that replacing the display panel alone may resolve the issue.
  3. I would advise testing with a known-good display panel and then proceeding from there.
Cheers!
Joshua
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matthew davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
