跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
iPad 2 3G Digitizer vs WiFi Digitizer?
I have repaired a Wifi only iPad 2 in the past.
I have now got to repair the digitizer on a 3G version of the iPad 2.
Are there any differences between the 2?
Any additional steps / cables?
Thanks guys!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
same steps
only be careful with the 3g module in the top of the devise
in the top of the logic board is the 3g module,the antenas are conected to this part like the wi fi antena (the antenas are in the top op the devise next to the front camara)
be careful whit the cables when you take of the logic bord
in my experience,that is the only diference i watch
这个答案有帮助吗?
得分 2
添加一条评论
There is a differance in that they are NOT interchangable. The 3G version digitizer does not function properly when installed in the WIFI model pad. You need the propter digitzer for each. Most sites don't say anything about this. I found out the hard way. Look at the www.gendermender.com website to find the right application.
这个答案有帮助吗?
得分 1
添加一条评论
Is there a difference between the digitizer for a 3G and a Wi-Fi?
这个答案有帮助吗?
得分 0
添加一条评论
No difference Box intake the same Chip Slot in the Lower Left Panels of the Digitizers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,523
