跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Small White Spots after screen replacement
After replacing my digitizer, I proceeded by wiping the lcd with a microfiber cloth. I think I wiped a bit too hard and there are faint white spots when displaying something with a black background. Is there any way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Those could either be pressure points meaning something is under the screen pushing up on it or it could be a defective LCD. If you can get that screen off in one piece as those spots disappear then something is putting pressure on the display. If they’re still there when you lift the screen off then it’s a defective LCD and you should contact the supplier to get a replacement or refund depending on their policy.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimmysofat6864 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 357
