跳转到主内容
Repair and disassembly guides for iPad accessories.
90 个问题 查看全部
Pencil by 53 battery replacement?
Is anyone familiar with the Pencil by 53? It’s a Bluetooth art stylus for iOS devices that was discontinued in 2016, and has no relation to the Apple Pencil. I have one, and I have some old versions of apps that support it, but the battery is worn out from age and the stylus only works for a few minutes.
I was wondering if anyone knows how to open it non-destructively, and where to source a replacement battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have the same stylus and the battery is very easy to remove and replace if you pull on the tip (the same way you would to charge) the battery together with the tip will come out then you will notice that the tip has a twist mechanism, (also used to switch the tip) if you remove the battery module and the tip all that’s left to do is find a replacement part.
这个答案有帮助吗?
得分 0
1条评论:
Oh, that half is just the battery? I've never torn the stylus all the way down so I thought a significant portion of the electronics were inside that part, so I could get it open and replace just the cell.
完成的
添加一条评论
添加你的答案
Sunset 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 208
