跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Right joy con won't turn on connect
Also tried third part and new left con works as did the original but the right will no connect wirelessly or docked. So frustrating. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You may have to take it apart and make sure everything is connected properly. I’m having trouble understanding your wording did you get a new set of joy cons and the right cons from neither set work or do you mean that you have so far only replaced the left?
这个答案有帮助吗?
得分 0
2条评论:
Tried whole new joy cam system and although right is flashing it won't connect. My original doesn't even turn o.
完成的
The problem is most-likely the right side of your switch, if you don't want to go through alot of trouble I would suggest you just get a pro-controller honestly.
完成的
添加一条评论
添加你的答案
Luke Baines 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 439
