跳转到主内容
Repair your Dyson V7 Motorhead vacuum with a part replacement guide.
1 个问题 查看全部
Dyson v7 Motorhead flashing red lights and not charging.
Hello, my Dyson v7 motorhead isn’t charging. After pressing the button to use it, the vacuum would flash a red light at the bottom for a short while before shutting off. The same happens upon plugging it in. Does anyone know what is going on, if so how do you fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
first check if its over 12 blinks or less if more its the battery if less its the motor so if its more you need to replace the battery if less search it up
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like you probably need a new battery. If it flashes red 10 or fewer times, the Dyson website says you need to contact them. But if it flashes red 12 or more times, then it's just a dead battery. Order a battery here on iFixit. I'm waiting for mine to arrive tomorrow.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle Mills 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 66
过去 30 天: 359
总计 5,563
