跳转到主内容
加入维修社区 - 创建账户
The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
iPad won't turn on
iPad Pro 11’ won’t turn on. The port is clean. It won’t turn on despite being fully charged. Unable to read diagnostics.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Bernie,
it's been a while and you probably have done it by now. Maybe it will be useful to someone. Unable to read diagnostics because it does not start. If you look at the closer you will find that it is drawing approximately 200mA when you press the power button. This is a problem to be solved in a good repair shop. Probably the damage was due to a defective cable or charger. Similar damage may occur with excessive wear of the charging port (usb-c in this model).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bernie Wolter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 272
