跳转到主内容
Released in Feb. 2018, it is the newest light-weight 14-inch HP Chromebook with a built-in Chrome OS and a 7th gen Intel Celeron processor N3350.
4 个问题 查看全部
How can I reset a managed chrome book back to factory?
Hello, I picked up a chrome book from a recycling center. Bought it for the screen. Turns out the chrome book is newer than the one I was using. I now use this one but cant seem to find a way to remove the system manger.
''”Your Chromebook is manged by __________.ORG” ''I’ve done a power wash and reinstalled the OS. *Please help me remove the managed system so that I can use it and manage it myself.* Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Just confirming you did this (from google support):
Factory reset your Chromebook
  1. Sign out of your Chromebook.
  2. Press and hold Ctrl + Alt + Shift + r.
  3. Select Restart.
  4. In the box that appears, select Powerwash. Continue.
  5. Follow the steps that appear and sign in with your Google Account. ...
  6. Once you've reset your Chromebook:
If so then this question has already been answered if you searched the forum. Please do that next time so that it’s not a repost of something already answered.
but it’s also possible you have a newer model that does not allow you to do that above actions:
My chromebook has an admin on it, how do I remove it?
If that is the case, there are two more routes you can take:
  1. Install CloudReady OS (Home Edition) onto your Chromebook. It’s a ChromeOS-clone that is designed to be run on a wider set of devices (like desktops, laptop or macs).
  2. Install your favourite flavour of linux (Manjaro or Mint Linux)
这个答案有帮助吗?
得分 1
2条评论:
Yes i searched and saw this answer but wasn't sure if that would work for all chrom books. Do you think it will work with HP?
完成的
Well Google is trying to do what Apple does and limit the ecosystem with specifications. So all Chromebooks have a certain standard setup. According to the second link, the newer Chromebooks have removed this security workaround. *IF* you are reluctant to open your Chromebook, I suggest you install CloudReady *BUT* I'm not certain if they also adhear to ChromeOS enterprise management. Never had the opportunity to try myself.
完成的
添加一条评论
添加你的答案
john 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 52
总计 4,465
