跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Will fixing a metal plate to the back affect GPS reception?
We're making a child proof iPad case that will add two big handles to the side of the iPad by sticking a big plate of metal to the whole back. When it covers the black area of the GPS antenna, will it affect the reception of it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Rolf,
I don't imagine that your GPS will be greatly affected, if it is even affected at all. There are often much larger and thicker obstacles between you and your GPS source, such as walls, cars, people and several hundred miles.
这个答案有帮助吗?
得分 0
2条评论:
Thanks Philip! But why does Apple put the black plastic part there then? Must be for the same reasons?
完成的
I honestly couldn't tell you. I stared at one and didn't see anything significant and I don't see anything exciting about it in our guides. It's possible that it might house the GPS antenna to isolate it from shorting? But perhaps another user has an answer to it's functionality :)
完成的
添加一条评论
添加你的答案
Rolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 767
