跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
iPod 4g new battery not charging.
My Ipod Classic 4 g new battery will not charge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery may be faulty or the charging port. I would suggest clean the battery connector with isopropyl alcohol. If that does not work you may have a faulty battery. To see if you do try placing the original battery and see if it charges. If the original battery charges and you bought the new battery from ifixit then email support@ifixit.com and say that you have a faulty battery and they will send over a new one. If both the new and old batteries will not charge then it could be the charging port. Apple soldered the charging port directly to the logic board to the only way to replace the charging port is to replace the whole logic board.
Hopefully this helps, Richard.
Happy Fixing!
-Javen
@tacofixes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RICHARD GRENIER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
