跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
241 个问题 查看全部
No power on water damaged MacBook Pro
I have a 2016 Macbook Pro that was water damaged 6 months ago (water bottle spill in a backpack). Unfortunately, it was powered up without inspection and was fried. There is ZERO power getting to the laptop. Any first steps to check? Everything looks perfect in regards to the logic board, etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Letting it sit was the worse thing you could have done! So you’ll need to decide how much are you willing to spend on fixing this system.
Does it only need a battery? Does it need the logic board repaired or replaced? That may push the costs to the tipping point if it’s badly damaged.
What is your skill set? Replacing a battery is not overly hard but I’m sure your logic board has issues from sitting wet for so long. I would at least pull the logic board to inspect it for corrosion damage.
这个答案有帮助吗?
得分 0
6条评论:
It was my daughter’s and she was going to throw it away so I thought I would give it a go. My skill set is above average. I don’t want to spend over $500-800. Past that and I might as well buy an older used model for $1K.
I was hoping to take it one step at a time and slowly replace parts until it gets too expensive.
What would be the first step? Buy a new battery and see if shows any kind of life? Is there a “first diagnostic step” when there is no power?
完成的
Try plugging in a replacement battery (don't install it, just plug it in) any life?
完成的
Take out the battery and see if there is any light on the charger after plugging in?
完成的
Also if you check your motherboard model number and post it here, maybe with some close-up photos, we could point you in the right direction.
完成的
@honakrisi - FYI - No LED on the charger you're thinking MagSafe.
You would need a USB-C power meter to see what is happening like this one USB-C power meter.
完成的
显示更多的1条评论
添加一条评论
The first thing to go with water damage is usually the keyboard and trackpad assembly, and also the battery, the logic board as long as it wasn't a lot of water should be fine, at least with older retina and unibody MacBook Pro's. I would recommend ordering a top case and a battery. Then pray to whatever you believe in. Also do any of the chips on the logic board feel really hot when plugging it in. If so the logic board will need either a couple of chips replaced or the entire board. Also remove the logic board and check for corrosion as Dan said.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Chenoweth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 133
