跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
Camera works but doesn't work
I recently dropped my iPhone and the back cracked forming a little rectangle around my back camera unit. My back-facing camera doesn’t work when using the camera app. However, when I use the camera via the Instagram app it works but it is zoomed in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are two camera sensors in the rear camera assembly. Do into the camera app and switch between modes while holding your finger over one or the other then try the same in instagram. I’m wondering if instagram uses a different sensor. If you confirm the camera is damaged then you can get it replaced however you may lose FaceID if you or a third party replaces it as demonstrated in this video: https://www.youtube.com/watch?v=Apny-yVr...
Mind you this is a shady business practice by apple that we’re trying to fight against called Right to Repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rithraj Bondili 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 52
