跳转到主内容
What type of screwdriver is required to open the fan?
Hi,
I’ve managed to open the laptop successfully and replaced the thermal paste, however, the temperatures are still high. I believe there is dust stuck within the fan but I don’t have the screwdriver which open ups the fan.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Dell usually uses philips PH0 or PH00 screws. Make sure you double check that the screws around your CPU and or GPU heatsink are torqued down. It is not uncommon to forget to tighten one down. Also, try just using a compressed air can or compressed air to blow the dust from the fans / heatsinks. If you don’t have access to that, very lightly dab water on a q-tip and try to remove all the dust that you are able to reach. Do this only to fan and heatsink components and not circuit board components. Good luck!
这个答案有帮助吗?
得分 0
1条评论:
Hi,
Thanks for your reply. I have ordered the screwdriver types you have mentioned.
完成的
添加一条评论
添加你的答案
Ali Khan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 632
