跳转到主内容
加入维修社区 - 创建账户
Released in 2011, the Lenovo B575-1450 has a 15.6 inch screen with a 320GB hard drive, and comes equipped with a fingerprint sensor.
My laptop won't turn on after locking itself from a low battery
Super confused right now. I asked my dad what to do about this and he told me to leave it for a day or two plugged up but I’m not convinced. It’s been plugged for the last 10 or so hours and I’ve just attempted to turn it on. The power button light turns on at the slightest touch and the lights at the bottom left all light up. I can hear a fan turning on, and then stopping and dying. This is better than it was several hours ago when the battery light at the bottom left was red (it’s now a sort of orange-ish colour) and the fan never whirred once. There is a little beep when it turns on, but nothing else happens and the screen stays off. This is the first time it’s happened with me and I’ve no idea what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @froginthereeds ,
Disconnect the charger from the laptop and then remove the battery from the laptop.
Here’s the ifixit Lenovo B575-1450 Battery Replacement guide that shows how to remove the battery.
Press and hold the laptop power button operated for a full 30 seconds and then release it.
Reinsert the battery into the laptop
Plug in the charger and try to start the laptop.
Try to start the laptop.
If it starts a there may be a message about the date and time being incorrect. This is normal as the BIOS has been reset
Once it has been corrected it will not appear the next time that the laptop is started
Once the HDD activity has settled down check the charge status of the battery. If it is charging allow it to fully charge before disconnecting the charger from the laptop
Also create a Win 10 battery report to check the status of the battery.
Compare the design capacity versus the full charge capacity to get an idea of the state of the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frog In The Reeds 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 2,870
