跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Home Button Not working after replacing Battery
I just replaced the battery on my iphone 8, No problems with that repair. But the home button no longer works, Touch ID and haptics work, but home button is dead.
The Button/touch ID assembly at the bottom of the phone is in perfect shape, no cuts, breaks bent parts, I never even touched that part but I checked anyways after. I even messed with the tension on the screws to see if that was the problem
The only thing that looks like a possibly is a extremely small tear on the the digitizer cable right before it connects to the logic board, although the tear is less than a mm into the cable and it doesn’t even look like it reached the traces.
This seems strange as disconnecting the display was the second step in all of this and I didn’t mess with anything in that area of the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you see a tear, it is a tear.
It is super easy to tear this cable. In the factory or repair service center, there is probably a fixture holding the screen up while assembling to remove any possibility of tearing it.
In DIY scenario, the cable is often torn because the user just laid the screen flat.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
NotaPro 12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 209
