跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Replaced HDD with SSD and now fan is going crazy
Replaced HDD with SSD and now fan is going crazy, I did attach the temp sensor to it to that bought from here on iFixit. Haven’t put the lcd back on all the way because of this. Can someone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your systems SMC is looking for the thermal sensors within the display assembly which is why your system fan is running hard and your CPU is down clocked as well to protect it from overheating.
So carefully plug in your display cables that should resolve things. If not run the onboard diagnostics. Restart your system and press the D key to enter.
Reference: Mac startup key combinations
Let us know what you get for an error.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Austin Flatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 42
