跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
When powering on apple logo appears then screen goes black
Hi All
I've replaced battery in this ipad and now when I power up the apple logo appears on the screen for around 2seconds the screen goes dark, I'm saying dark as I still believe its powered as when I press and hold the power button it goes black there is a definate change.
Any help and advise would be helpful….its apparent that is something I've done. Would be good to know what!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Can you put the iPad in restore mode? Try to press the power and home buttons at the same time for about 20 seconds, until you see the “Connect to iTunes” screen. If you can do this, most likely a factory restore via iTunes will solve the issue.
If you cannot put the iPad in restore mode, then the problem is way more serious and very likely in the motherboard.
这个答案有帮助吗?
得分 0
1条评论:
Of course, try to put it in restore mode while connected to the computer or the wall outlet.
完成的
添加一条评论
添加你的答案
Barry moore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 16
总计 116
