跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Reading Data from Fusion Drive
My iMac doesn’t seem to want to boot anymore. Black screen and no startup chime when I try to boot it, so no access to Target Disk Mode. My latest backup is more than a year ago. I have an internal HDD and an external SSD as a Fusion Drive. I’m not 100% sure how a Fusion Drive works, but would I be able to take out the internal HDD and use an external enclosure with the external SSD on another Mac and get access to the files?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, you can actually remove the internal HDD and slip it into an external SATA to USB3 (USB2 is very slow so please try to get USB3) enclosure and actually boot off it on another WORKING mac (that is at least 2011 or newer). If you place it in the working mac, hold the ALT/OPTION button and power up, it will show you the connected drives with the external HDD looking like a “yellow” drive icon.
You want to do this because you can then log in as yourself with all the permissions intact and then back up the contents. If you try to access the drive from another working mac, you have to enable permissions/etc which is beyond the scope of my abilities to tutor you on. This is especially true when you want to open certain mac specific apps to gain access to your old passwords because you never remember then (like me).
Also, your SSD should have more frequently accessed files so it migth have recent copies of frequently used content (videos, images, notes). You might want to check that as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 422
