跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 个问题 查看全部
PSP will not work without charging and also will randomly shut down
PSP will not work without it charging and even then will randomly shut down and factory reset. Ive changed the battery numerous times and checked the charging output which at first, the charger that came with it was not supplying enough power to charge properly. I got a stronger cable (one that is recommended for the PSP through Sony) still have same issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It can be an issue with the battery connector. The cable that connects the battery to the main board might by dirty and have corrosion which is causing the battery not to work. Get some isopropyl alcohol and clean the battery connector’s contacts and also the socket where the cable connectors. As to why it randomly shuts down I am not sure
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Al Feidt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 304
