跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
How to open case with stuck rubber seal?
I am trying to open my iPhone case, removing the display assembly, however the it seems to be VERY stuck, so much that when using a case opener or suction cup it pulled the glass off the top and not the whole assembly. How can I get this thing apart, I have all but ruined the case opener tool trying to wedge it around the seal with no luck. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What damage has it sustained?
完成的
I was trying to open it to clean the speaker ad try to fix the volume up button. I have previously been able to open it up via suction cup not now since the adhesive isnt holding.
I just replaced the adhesive for the bottom part of the glass and once I let it sit for a bit will try the suction cup again.
完成的
添加一条评论
1个答案
已选择的解决方案
dud if the glass lifts, let it, then use something metal (i use a small flathead screwdriver) to get the assembly out whilst holding the glass out of the way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adidascchs 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 3,376
