跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Video intermittent when docked
The video output is intermittent when docked. The switch will charge and another switch works fine on the same dock. Do you think the problem would be the USB C port on the switch?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Thanks for the reply! After your tip I dug around in the with a toothpick, that didn't work so I brushed it out with a toothbrush and alcohol and that still didn't work. It will work if I fiddle around with it in the dock sometimes but is intermittent. I feel like a cord plugged directly in the fits ok and isn't loose.
完成的
添加一条评论
1个答案
Hi Matt,
Most commonly the cause of this pesky problem is dust or lint getting stuck in the USB port on the console itself.
Does the charging cable go in snugly with that click you can feel? I’d recommend gently trying to pluck out any debris with some tweezers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Saeger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 113
