跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
NDC001 error code after screen change
Hello, I bought a 2017 MacBook Pro A1708 without Touch Bar with a broken screen. After changing the screen and doing a diagnostic I have the error code NCD001 which means the camera is not connected and therefore not working (FaceTime and photobooth). After performing the following operations: SMC, NVRAM, it still does not work. Has anyone had the same problem as me and if there is a solution I'm in! Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hey did you ever get it figured out?
这个答案有帮助吗?
得分 0
1条评论:
No, I didn't found the solution
完成的
添加一条评论
i’ve same problem too!
这个答案有帮助吗?
得分 0
1条评论:
wonder if anyone managed to figure it out. Im thinking it might be the flex cable that was damaged?
完成的
添加一条评论
添加你的答案
Noémie THOMASSET 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 535
