跳转到主内容
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 个问题 查看全部
Why is a quarter of my screen going bad, can it be fixed?
All of a sudden after some flickering a quarter of my screen on the left side has gone bad. The colours are not what they are supposed to be like on the rest of the screen. There’s a split by a vertical line. Is this a software issue or a hardware issue? Can it be fixed without replacing the entire screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you have the same bright/dark division it is a hardware issue. If the BIOS looks fine then you are looking at a software issue.
If your MacBook is still under the original warranty, you should contact the Customer Support directly to have them put you in touch with the Technical Support to see what they can do about troubleshooting remotely.
这个答案有帮助吗?
得分 0
9条评论:
Thank you! I think it’s a software issue then because the start up screen with the apple logo doesn’t have the weird division. I also did the diagnostics (startup with D) and the division wasn’t there either and the diagnostics came back with no issues.
完成的
@lauyen Good to hear that, you may do something to further troubleshoot which software has caused the issue.
完成的
@v3nuo ,thanks how do I do that? I just upgraded to Big Sur and the issue is still there :( Maybe I have to downgrade.
完成的
You may try booting into safe mode to see if that fixes the issue.
完成的
@v3nuo Yes I tried that already, the screen was like that too in safe mode.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Jen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 42
