Constant restarts after water spill, opened and cleaned, still no joy
Sorry this is a bit long, but I want to fill in the details.
Filtered water was spilled into a 13” MBP Retina while it was running on battery power. I opened the back cover and blotted up as much water as I could, then let it dry for several days.
On attempting to restart, it did nothing on battery, but started (on its own) when connected to the power adapter. Everything seemed normal, except a battery icon with an exclamation point, and a keyboard icon with US.
All keys seemed to work. The charger was orange, but then it said “service battery” in the menu bar. When the charger was disconnected it immediately shut off and would only start on the adapter.
That night, when plugged in, it would start and get to password screen, then randomly shut down and restart. It will do this over and over, never restarting at the same moment after the password screen and restarts endlessly regardless of using the keyboard, trackpad or anything. Resetting the SMC, zapping PRAM and disconnecting the battery and the keyboard didn’t change anything. Holding the power down breaks the cycle, but a soon as I hit the start key it starts again.
I stripped the whole thing down and examined the logic board and all circuit boards. Only one of the water detection dots turned a bit red, the one to the right of center at the bottom of the logic board. I found some blue corrosion on the battery board where the battery connects to the logic board. I cleaned everything I could with 91% alcohol, let everything dry, applied the thermal paste and reassembled and it didn’t work. It starts on its own and keeps restarting.
I can’t run any diagnostic or do anything else because of the restarts.
Since it does this without battery and keyboard disconnected, I assume the problem is not the keyboard. I didn’t disassemble the keyboard.
I’ve heard a dead battery can cause a boot loop on these models. Could it be the battery board has shorted, and I just need to replace the battery? It seems the board comes with the new battery, so it would be replaced.
Any thoughts are appreciated!
1条评论
Turns out, it will not start at all when connected to power but the battery is disconnected.
由 Spotopolis 完成的
