跳转到主内容
An external drive with USB 2.0 and Firewire 400/800 interfaces. Comes in capacities between 320 GB and 1 TB.
7 个问题 查看全部
Using WD Passport mini USB In a MacBook Pro model A1211
I have a Macbook Pro 15in with a 120gb HDD and I also have a WD My Passport usb HDD 500gb .
Can I use this drive has an upgrade into my Macbook?
I had removed the case of the WD Usb HDD and it have exactly the same connection that a normal SATA hard drive PLUS a miniUSB Port.
So will this fit in?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
If the miniUSB port is mounted on a short HD mother board extension that extends about 1/2" behind the metal edge of the hard drive , the drive overall length is too long. I pulled mine apart about 6 months ago and found that the board was too long to fit the existing drive bays. If that doesn't sound like your drive please take a picture of it and put it on your posting and we can give you a better answer.
这个答案有帮助吗?
得分 1
2条评论:
I'll post a photo soon! Thx the answer !
But the mini USB is directly on the drive itself i don't think there us some kind of motherboard lile you talking about!
I didn't see a laptop sata before so i cant if its the same size.
Ill post a photo with a scale so u can see exactly how big it is.
完成的
i've had some image! tell me what you think! thx
完成的
添加一条评论
Photo 1
Photo 2
这个答案有帮助吗?
得分 1
添加一条评论
Sorry for the delay. I looked at your pic's and it is the same as my drive. It is too long for the Mac laptops I have worked on. Most drives that will fit in the Macs cut off at the edge of the metal case and do not have that extension.
Also I forgot to mention the cable on the Mac SATA connector can not attach to the drive because of the extra hardware. And I think if you look you will see slender pins coming out from the back of the drive over the board and those are not able to hook up to the cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Danny V 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,574
