跳转到主内容
Phone echos very badly after repair
I can’t remember if this started before or after the screen repair I performed, but it was around that time. If I’m on speakerphone or a video chat, the other parties can hear a bad echo. Sometimes it just sounds “laggy”. Some of the troubleshooting steps I have taken include:
Factory reset
Replace charge port (has a microphone on it)
Replace loudspeaker
I have no idea what else to try. I repair phones daily and have never encountered something like this. Any and all solutions welcome. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @e_ahh ,
Don’t know the answer but have read that the Galaxy Note 9 has 8 wide field microphones, so maybe you need to recheck all the connections that were disconnected due to the screen repair.
Presumably the mics are used when in loudspeaker mode and also perhaps for noise cancellation when on a “normal” call.
What is it like when on a “normal” call which primarily uses the microphone near the charge port, you didn’t say?
Here’s a link to the service manual that may help.
这个答案有帮助吗?
得分 1
2条评论:
If by "normal" you mean using the earpiece it works perfectly fine. No echos or any other abnormalities. And yeah I've completely stripped the phone 2 or 3 times out of boredom just to see if there would be any changes and to insure all connections are solid. No luck
完成的
Did you ever find out the problem? I'm having the same problem...
完成的
添加一条评论
添加你的答案
Ethan Leroux 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 676
