My battery reporting is stuck at at 80% on the app and the speaker?
So I have recently had a Megaboom 3 replaced under warrantee because I was getting an issue with it being stuck on 80% charge. On my new replacement it stays stuck on 40% or 80% (normally stuck on 80%) it never drops to 75% as an example.
I use both the app and the speaker to check the charge level. I have tried to reset using the power and volume down button. I have also tried the following:
"Volume Up and Down and the Bluetooth button at the same time WHILE the speaker was plugged in with the Volume Down button"
I have tried using the power up charging doc, and a cable. This is really strange because its the exact same with 2 different Megaboom 3, I swear it was not behaving like that before. Am I going insane?
Has anyone else experienced these issues.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
