跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
No sound after replacing lightning connector
I replaced the lightning connector on my iPhone 6s Plus yesterday and reassembled it only to realize I have no sound from the loudspeaker. I can hear through the headphone jack. The microphone works as people can hear me when I call them but I can’t hear them on the loudspeaker. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure the new connector is firmly connected to the board and that there aren’t any bent or damaged pins or tears in the new assembly. If that’s not the issue check to make sure the speaker can make contact with the lightning connector. There should be a couple pins that make contact with it. If that doesn’t work then you may have a defective part on your hands.
这个答案有帮助吗?
得分 0
3条评论:
how would I check that the connector is firmly connected to the board? How do I determine if the speaker is making contact with the lightning connector? An image of the proper connections would be invaluable.
完成的
@Robin there's a couple ways you can check those. You can disconnect and reconnect the lightning port and give it a few firm presses on each end to make sure it clicks into place. But before you do just check the connector and make sure there aren't any bent or damaged pins. Once you've done that, take the loud speaker out and make sure the pins on the underside aren't missing or damaged or that there isn't anything in the way.
完成的
thank you for your help.
完成的
添加一条评论
添加你的答案
Robin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 78
