跳转到主内容
Repair guides and support for your Samsung TV.
2618 个问题 查看全部
Samsung Plasma TV Has no power and no red light
I have a Samsung plasma TV model pn51f4500af. It randomly had no power one morning after it was working just fine the night before. No red standby light or anything. After reading through other guides, I have assumed it was a bad power supply or a bad fuse, So I just went all out and bought a new power supply. After taking the back off, and removing the old power supply, and reattaching the new one, I am still not getting any power to the TV and no standby light still. I had purchased another power cord to rule that out also. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
service manual will be a waste. problem is main board - something on that board (most likely eeprom) is loading down 3.3V line. without 3.3V main board will not turn on set. You can force the set on thou - jumper pins 3-4 on main board. jumper PS_ON to ground - plug tv in and set should display test pattern. BAD MAIN BOARD
这个答案有帮助吗?
得分 1
添加一条评论
Hi @mmatt2004 ,
Don’t know the answer but it may be worthwhile to buy the service manual as it should help and save a lot of time
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matt mocciola 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 14
总计 561
