跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Looking for Display hinges MB Air A1466
Hi!
The Display from my 2017 MB Air (A1466) is wobbly.
Before I start to fix it, I wanna order new hinges. Then I can replace the older to the new hinges.
But….where can I buy such hinges?
I have found a link to aliexpress, but there are only hinges for MB Pro 13”
https://de.aliexpress.com/item/400008732...
Also the delivering time is earliest Apri,,,
Is here anyone who can help me to find the suitable hinges?
Thx in forward..
Joe, Wiesbaden, Germany
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Here’s the needed hinge parts for your system:
Often the screws are just loose, sometimes the clutch mech seized which will require new hinges.
这个答案有帮助吗?
得分 1
添加一条评论
The hinges are part of the whole screen assembly and required you to pretty much disassemble the screen completely (including the front glass panel & such). As a first step I would just recommend to tighten the screws of the hinges.
Have a look at this thread: Can I replace the hinge set only? since it’s a similar issue.
I had a look around and could only find a replacement hinge for the left side with the display cable. It doesn’t seem to be a common repair part I’m afraid.
You can also try to apply some nail polish when tightening the screws to prevent them from coming loose as suggested here: Hinge is loose how to fix?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Blessing 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 510
